The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3700 Questions View all
Why is my iPhone 5s rebooting every 3 minutes.?
I have replaced my iPhone 5S Display and housing.
Including my battery, after it worked a couple days no problem, now i have Blue screen reboots every 3 minutes.
I don't know why it happened, i searched about it and found nothing that could've happened to mine cause i do not have the metal bracket ontop of the Display Flex cables screwed in.
Could it be the battery that's damaged? Logicboard?
Thanks for any help
Ps: i have restored my iPhone and other stuff with no succes.
Comments:
How old is your iPhone? Maybe the battery is dead.
by
Add a comment
Free shipping on orders over $20
Use code BLUEANDBLACK at checkout
1 Answer
Chosen Solution
Hi, this could be due to long screw damage, did you make sure to put all the screws back in the correct place? If not then you may have caused long screw trace damage, and this would require microsoldering knowledge, as this causes the blue screen.
This could also be down to your battery, I would also try a known working battery, if not, check if there is any long screw damage in bottom right screw hole of Lcd shield. :-)
Score 1
Add a comment
Add your answer
pbinh01 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 14
All Time: 286
