2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache.
774 Questions View all
Question Closed
Installed a 2013/2014 LCD Assembly into a 2015 MacBook Pro A1398...
Hi all,
Due to a careless technician who is no longer with us, we have been having a nightmare on a macbook pro. It is a 2015 A1398 Macbook Pro 15" Retina.
We have installed 3 separate LCDs now (came in with a cracked LCD)... thinking each LCD was dead. We realized on LCD #2 and #3 that the LCD was working, but that there was no back light. When you hold a flashlight to the screen you can see the display. Otherwise the computer seems perfect (when booted to external monitor via hdmi).
We realized yesterday that our ex-technician ordered the wrong screen all three times. He ordered the 2013/2014 A1398 instead of the 2015 A1398.
Does anyone have any ideas on whether or not it might be the LCD or the logic board? Is the 2013/2014 LCD assembly truly incompatible with the 2015? And if so how is Apple capable of doing that? Everything fits perfectly... they are practically identical laptops.
Any and all advice would be SO appreciated.
Add a comment
Chosen Solution
Best advise here is to order the correct part.
Score 3
Add a comment
This answer was originally to another question.
My father had the same problem with his Macbook Pro. I fixed it just by turning it on and letting him typ in his password. I believe after that it just fixed itself (it's been a while since it happened). Maybe try changing the brightness of the screen after logging in. I don't know if this will work for your clients Macbook but I hope it does.
3 Comments:
Unfortunately this isn't doing it. We tried that. Thank you for the suggestion.
The real question here is will a 2013/2014 LCD work on a 2015 model
by
Did you find out?
by
As far as I can tell they do work but the webcam isn't detected properly. Although the connector fits lvds cable fits etc. It won't play nice with the webcam...
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 1,699
