Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
Is it possible to change iPhone 5 camera to iPhone 5s camera?
Is it possible to change iPhone 5 camera to iPhone 5s camera? Will it work? It has similar cables.
Add a comment
Chosen Solution
I honestly don't know off hand. Guessing you're talking about the rear camera. If you have the parts on hand, I would say try it. The cables may look similar, but they may have different connector sockets. So it's very likely it won't work, but I don't for certain off hand
Score 1
2 Comments:
I suppose, that, if it have different connector sockets it can damage mainboard or camera module. But maybe someone tried it, or know answer on this question. And i don't know anything will it work in iOS for iPhone 5, drivers can affect on it.
by
I have a couple of these things on my work bench. I'll give it a whirl, and see if I can come up with a definitive answer
by
Add a comment
Have you tried it? I have the same question
1 Comment:
Rear camera connector is inverted, one model plugs under logic board and one above.
For front camera the earpiece connector part is different 2 connections vs 4.
Do not try it. I've seen ribbon cables and / or FPC connectors to the part get burnt / melted / damaged by doing so.
For example plugging a 5s charging port into a iPhone 5c. I ended up melting the charging cable at the plug lol.
Funnily enough the charging port still worked when I tried it on iPhone 5s.
by
Add a comment
Add your answer
Beckon Beckon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 130
