13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Questions View all
Can I reattach parts that sort of came of while repairing?
OK hi,
I tried the Fan Step By Step Guide and I kind of did all right, but when it came to the point where I had to disconnect the cables from the logic board a problem occured and i sort of took the whole thing off. So now i cant reattach the cables to the logic board because the mounting came off as well. Now I’m looking for help rather with soldering or anything that could help.
Thanks a lot
Leo
Score -1
Add a comment
Chosen Solution
With a small soldering iron and a steady hand you can try your luck and resolder the socket. Magnifier helps. Otherwise the alternative is a new logicboard :-(
BTW. you pull the connector straight up, a point that should be mentioned more clearly in the guide. A lot of people had these troubles.
Add a comment
An electronics shop
might be a better solution than a DIY fix. The electronics shop should have all the equipment and skill to directly solder the wires to the board.
If this answer was helpful please remember to mark it accepted.
Good Luck,
N
1 Comment:
Soldering logic board components requires special tools, and lots & lots of practice. It's very easy to damage the circuit board if you've not had lots of experience.
by
Add a comment
Add your answer
leo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 685
