output voltage for computer
if the output is 18.5v and i hook up only a 16.5v power cord to the computer, will it be enough to turn it on?
Though the 60 W MacBook and 85 W MacBook Pro MagSafe connectors are identical, Apple recommends using only the adapter provided with the machine. The MacBook Air has a smaller 45 W version of the MagSafe adapter. (Note: The 13" MacBook Pro use the 60 W Charger, while the 15" and 17" use the 85 W)
The inner large pin is V+ @ 16.5 VDC. Measuring with no load will give 6.86 VDC; the full 16.5 V is provided to the proper load.
The outer large pin is ground.
The tiny center pin appears to be a charge control pin to change LED color and possibly adapter switch off.
great Answer. +
my macbook pro charger is damage, can i use other charger from other laptop, 65w but 19 volts
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,381
