Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
MacBook Pro won't turn on and charger is dim green?
Okay, so, my trackpad stopped working. Then, the light on the front of my macbook would come on when I closed my mac, but when I opened it, the light would go off. I then shut down my mac and it wouldn't turn on. So I unplugged the battery, plugged it back in, and did the whole 10 second trick (I already know that) and it still won't turn on. So now, my charger shows a dim green light when plugged in. Also, with the battery lights on the side, there is 1 on, it's not even flashing, just on.
Score -1
3 Comments
Unplug your trackpad from the motherboard then try to startup, see what happens.
by
Thanks but I just tried that, didn't work.
by
i suppose that you already did SMC and PRAM reset right? it help with such issues.
good luck
by
Add a comment
1 Answer
Chosen Solution
Check the pin out on the Mag-Safe adapter, here's the voltages on the right: https://en.wikipedia.org/wiki/MagSafe
Score 2
Add a comment
Add your answer
Justin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 2,538
