Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Touch ID Button glass cracked - repair w/o loosing fingerprint feature
Is there a way to just replace the glass on the home button? The Touch ID sensor does not work due to the cracked glass.
Score 1
Add a comment
Chosen Solution
No it's not possible, the sensor chip is thinner than human hair and extremely brittle. To make the matter worse, the chip is glued to the button crystal so there is no way to remove it without breaking it.
Score 3
Add a comment
Thanks because I knew it could be repaired on iPhone 8+ but I was thinking because in my case with cracked button glass I was Not able too repair touch id.
you are always right n you are here :)
Add a comment
Add your answer
Bartosch will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 13
All Time: 450
