Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1233 Questions View all
My iPhone doesn't Charge even after I changed battery... please help
Hey guys,
My iPhone 5c will not charge the battery, when i plug the cable i hear the beep so it tells me it detected the cable and power but it just won't charge. I have updated the software, changed battery twice and also changed the power supply and cable and still no luck... Please help me i'm lost!
Thanks...
Add a comment
1 Answer
Chosen Solution
Hearing a beep--do you mean that you hear the usb connect sound when you connect your phone to a computer? If so, this means that your phone is on, but just has no display.
Open iTunes. Is your phone detected in recovery mode? If so, you can restore (which will wipe your data) and the phone may be fine. If it is detected by iTunes but not in recovery mode then this means you have a display problem. Disconnect the battery and reseat the screen. If not solved, try a new display. If not solved troubleshoot backlight circuit.
Score 1
4 Comments:
Thanks for the message. I should add that screen is on already, the battery is at %49 and is going down. the beep is the sound when you connect power to the iPhone and you hear the charging sound. I also see the symbol of the charging icon next to battery and the battery symbol turns green but it just not going up. one thing I noticed was that looks like charging port circuit is replaced from what i can see, could be it the reason?
by
ok, so the phone is working normally but just showing signs of "fake charging"
For that problem, you can rule out bad battery, then bad charging port, and if none of these solve then you probably have a common chip level defect on the motherboard---a failure of the charging logic ic chip due to non-Apple charger usage, i.e. "U2 chip failure"
by
Thanks. That's my suspicion too. I tried one brand new battery so I'm leaning toward charging port issue. Is there a way to give shock to the phone that can possibly cure the issue? I'm talking hardware reset not the the hard rest using the power and home button.
by
no. you can't cure a hardware problem with a software solution
by
Add a comment
Add your answer
kari19 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 127
