Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
577 Questions View all
Why my samsung can't turn on?
my samsung galaxy s5 had only 16% battery left, so i listen to music over 1 night and in the morning my samsung can't turn on, i've charge it for 11 hour but still can't turn on the samsung..WHAT SHOULD I DO ?! HELP!
Update (12/26/2015)
Should i buy a new battery ?
Score 1
3 Comments
When you have it plugged in to charge is it showing that its taking a charge or are you just assuming it is. Your problem may be that its not actually charging . Try a different cable or different charger , hook it to your computer and see if you can connect to it
by
thanks a lot
by
so, i've try a different cable ( charger too) and it seem can turn on, but the problem is the screen is tonally black,..what should i do?
by
Add a comment
Chosen Solution
Possible battery failure, have you tried a known working battery?
Score 1
2 Comments:
what is known working battery?
by
A known working battery, a battery you know that works, like a friends battery.
by
Add a comment
Are you sure you are charge it for 11 hour?
2 Comments:
yes
definitely
by
You mean It is can turn on , but the screen is black,
It is possible that the lcd screen is out of work..
by
Add a comment
Add your answer
luciancifer will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 181
