Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Questions View all
4s screen Black and white, fuzzy after change
I changed my cracked screen with a replacement from ebay I got for 20 bucks aud. Everything including touch works fine except for the display. This is what I get:
http://imgur.com/RL7flsu
Is this more likely a faulty lcd or something I've done?
The dimming you see in the picture is not a camera effect. Thats how it looks.
Score 1
Add a comment
Chosen Solution
Did you take OFF the new screen protective sheet on the back of the LCD? If you installed the screen correctly and perfectly, then you need a new screen.
Add a comment
This can be faulty lcd or you damaged when were replacing... check the connectors.
I will recommend you before replace the new lcd, test it please and connect with out removing old lcd.
Add a comment
Add your answer
Simon Di Bella will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 7
All Time: 92
