The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
526 Questions View all
Everything seems to work but WiFi and Bluetooth. Antenna is good.
My phone will work fine when hooked to the mobile network. However, the WiFi and Bluetooth capabilities are not working. If I use the toggle switch, it will not activate. I have factory restored and it did not fix the issue. I also switched the antenna and that did not fix it. Please, any help would be appreciated. I would like to give it to my daughter to use as a music player that will hook to her Bluetooth speakers.
Score 1
Add a comment
1 Answer
Chosen Solution
You should check to see if your trying to be a mobile hot spot if this feature is enabled it kills the wifi and Bluetooth
Score 1
2 Comments:
It is not on mobile hot spot.
by
I keep seeing suggestion on to re-download the S4 platform, but I have no clue what software that is.
by
Add a comment
Add your answer
Stephanie Davies will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 168
