1.83 GHz Core Duo or 1.83, 2, or 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
257 Questions View all
Can the display be replaced?
Can the display be replaced? Mine is starting to have lines and streaks.
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
You can definitely replace the display. Just use iFixit's display removal guide for your iMac to get it back in running order. You can also use the same guide to check if the display plug came loose and was causing a problem (unlikely, but there's still a chance).
By the way, it may not be the display that's causing the problem. It could potentially be a faulty inverter, video card, or even the logic board.
Add a comment
Add your answer
blaine will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,278
