Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1233 Questions View all
Question Closed
Why wont iPhone 5c screen work after replacement
So i took my old iphone 5c that is icloud locked by some random person on ebay and I took the screen off that and put it on MY old 5c that had a broken lcd. Now after i did that the new screen wont light up unless i push really hard where the flex cables click into the logic board, how can i fix this problem? I didn't see anything stopping it from fully clicking or overall any problems.
Add a comment
hyrqBot check the connector very carefully. Check for any bend or folded over contacts.
4 Comments:
Also check for any debris in the FPC connectors, I often use a tooth brush and isopropal alcohol to clean the connectors, be sure to disconnect the battery first and wait till all the alcohol has gone before reconnecting, just to be sure that the contacts are clean.
by
i cant disconnect the battery, i dont have a heatgun to melt the glue under it. I have tried to remove it before and it like really fking stuck in there
by
just unplug it
by
oh right, thanks
by
Add a comment
if the connector looks fine and you feel that it is ceded in all the way than the screen is more than likely defective
1 Comment:
no, i put the screen back on the original phone and it works 100% fine, there is a small phantom touch but it lights and reacts to touch.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 115
