Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
Question Closed
No data sync and no charge
Hello
I replaced the lock flex cable on my iphone 5s. When I was done I had to hard reset the phone in order for it to boot, it wouldn't boot without it.
Now I found out that the battery will not charge, or when I connect it to my pc it won't show up on itunes and my pc doesn't even find it.
I have already replaced the dock connector and the headphone jack and home button still work.
Hope someone can help.
Add a comment
1 Answer
It sounds like it may be a bad U2 Charging IC.
2 Comments:
I also have that thought but it can't be broken because I replaced the lock flex. It worked fine before I replaced it.
by
If iTunes won't detect it , then it points more to the dock connector. Did you inspect the dock connector on the PCB for damaged pins?
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 77
