will not turn onwill
dell inspiro n 14
will not turn on,
screen remains dark
dell inspiro n 14
will not turn on,
screen remains dark
It could be a problem with static discharge , if so do the following.
1. Disconect the power cord
2. Remove the battery
3. Hold down the power button for 30 seconds , then release for 30 sec and then hold down for another 30sec
4. Plug in power ,replace battery and power on laptop.
If this causes no Joy try this.
Remove memory and reinstall one stick at a time, if there are more than 1 dimm of ram, try each stick in each slot one at a time to see if the memory is ok and to determine if one of the memory slots is bad.
Hope this helps
So much effort with such little information ;-)
@mayer this is a pet answer I keep for such occasions
normally means dead back light. try turning it on and shining a bright light into the screen if theres an image there the backlight is gone.
if not then its likely the connector between the screen and the motherboard. they tend to break at the bazel.
try connection your laptop to a external monitor
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 65
