Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Questions View all
Question Closed
little sign that it is charging,
I have the same problem but my saids is at 16% and it has the little sign that it is charging, but when I last looked at it it was at 14%. So is not really charging at all before i forget is the iphone 4. The night before I left charging over night but it didn't charge, and I don't know what to do. If you guys could help me please and I don't its because I kind of drop it. Help please
Add a comment
Most Helpful Answer
Rebeca Cantu, time to open up your phone and take a look at the logic board. Check the components around the battery connector and make sure that the connector is properly installed. If your phone comes on with a fresh battery but does not charge, it is possible that you have a bad power management IC. That is a BGA IC and needs special tools and skills to replace. It is also possible that you have a failed charging coil or "USB fuses". You will at least need a multimeter to check those components for continuity. Of course you also want to make sure that you have a known-good cable and that your lightning connector is in good working order.
Score 1
Add a comment
Try this, press home button twice to get the background apps. Then delete all the apps running in the background.
1 Comment:
Thanks but I did that and still wouldn't charge
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 48
