The Kenmore 90 Series is a washing machine manufactured by Kenmore.
266 Questions View all
Wash cycle works, has a clicking sound on spin cycle. Water drains!
Hello,
So my washer seems to wash without a problem, drains the water. Then, when it comes to rinse and spin cycle it gives a clicking sound. Doesn't spin or do the rinse cycle.
On the rince cycle I hear clicking sound from the motor
Any help much appropriated,
Thank you
Ron
Score 1
2 Comments
Mayor,
I greatly appreciate the quick response and the detailed answer! Thank you so much. So far I have verified it's not the lid. Working on verifying it's the coupler.
Thanks again!
Ron
by
Do you even found out what was wrong with your washer?
by
Add a comment
1 Answer
Chosen Solution
Cause 1
Lid Switch Assembly
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not spin. To determine if the lid switch assembly is defective, use a multimeter to test the lid switch for continuity. If the lid switch does not have continuity, replace it.
Cause 2
Motor Coupling
The motor coupling connects the motor to the washer transmission. If the washer is overloaded, the motor coupling will fail in order to protect both the motor and transmission. The motor coupling can also fail due to normal wear. Inspect the motor coupling to determine if it is broken. If the motor coupling is broken, replace it.
Cause 3
Drive Belt
Inspect the drive belt to determine if it is broken or if it is loose on the pulleys. If the drive belt is broken or loose, replace it.
Score 3
2 Comments:
Would it cause the pulsating click with the lights dimming on the same circuit?
by
@shrpwr MATT A short or something drawing a lot of power. Be very careful with this one as the machine may be electrically hot and zap you. This might be one to have a technician look at. IT's scary to me!
by
Add a comment
Add your answer
Ru Ru will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 27
Past 30 Days: 105
All Time: 50,756
