there is gap between the top and the case
there is gap between the top and the case on the front can this be fix
Your question is a little vague, but I'm assuming you mean a gap between the uppercase (with the trackpad built in) and the lowercase, not that the laptop does not close/latch completely.
This guide should walk you through removing the uppercase:
PowerBook G4 Aluminum 15" 1.5-1.67 GHz Upper Case Replacement
Inspect the parts for bends/damage, re-assemble correctly.
+ good
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 736
