Repair guides and disassembly information for laptops manufactured by ASUS.
lost windows windows corruption
how can i restore windows
Score 1
2 Comments
What version of Windows is it? How far does it get into boot? Do you know the cause of corruption?
by
Windows 10 I can't get pass utility screen
by
Add a comment
1 Answer
Chosen Solution
Get the appropriate windows disk for you OS then set your boot menu to boot from the optical drive . Once there select repair firs to see if your problem can be fixed that way if not then you will need to go to advanced and format the drive then reinstall windows. Make sure you have a valid oem key before starting . Hope this helps
Score 1
1 Comment:
Thank you I will have to get Windows disc and try this
by
Add a comment
Add your answer
betty alston will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 83
