Repair and disassembly guides for GE Microwave ovens.
door won't open when button pressed
I have a GE microwave/oven wall unit and the door doesn't open until 5-10 seconds after cooking or after pressing open button. There is no outside handle. I don't want to replace due to cost and installation in wall.
Add a comment
Most Helpful Answer
Cause 1
Open Lever
Inspect the open lever for damage. If the open lever is broken or damaged, replace it.
Parts
Cause 2
Door Spring
Inspect the door spring for damage. If the door spring is broken, replace it.
Parts
Cause 3
Door Latch
Inspect the door latch for damage. If the door latch is broken, replace it.
Score 2
2 Comments:
Our door does not open at all - so how would you be able to check for anything on the inside?
by
Ours is newly purchased and has this issue from the beginning. I have to push the button 2 or 3 times to open it when no food inside. After cooking, it is easy to open.
by
Add a comment
Check the latch that is inside as it might be dirty. This would cause it to open more slowly than expected. You might have a broken spring where the latch holds the door making it not move enough to release the door.
Score 1
Add a comment
Add your answer
Okcphinfan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 3,376
