Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
Replaced LCD screen, now it wont switch on
Hello,
first and foremost thank you for taking the time to read my question.
I have an iPhone 5S that recently fell and cracked the whole front screen, so I purchased a replacement LCD screen and decided to go the DIY route of fixing it. However, after putting the LCD screen back together, and when I attempt to either charge it or switch it on, I get no response whatsoever from the device..
What can I do? I have tried every single solution I could find on the net to try get a response but to no avail.
Score 2
Add a comment
Is it recognized in iTunes? This will help us determine if its actually not getting power or if the screen itself is just malfunctioning. iPhone 5s is also prone to longscrew damage so be sure you reinserted the screws in the correct order.
4 Comments:
Not at all, however when I pryed the front screen out, I used a needle in the bottom screwholes to push the screen out a bit because my suction thing was rubbish
by
Its quite possible a capacitor was knocked off the dock connector or another part of the motherboard from pry-damage. No need to worry (unless it was on the board and not dock connector), its actually a common occurrence and can happen sometimes. I would start with trying a new dock connector
by
I will try this, thanks!
by
This didn't work, I replaced the dock connector + headphone jack+ speakers, but its been on charge for 24 hours and still no life from the iphone.. what else can i do?
by
Add a comment
If the phone isn't powering on at all it sounds like a bad connection, regardless of whether it's the screen or something else it requires disassembly.
It's probably something relatively simple, and easy to do when you're inexperienced.
Disassemble it again and slowly reassemble, paying careful attention to the connections. Let us know the outcome.
Edit:
Try this:
  1. Remove the bottom 2 screws
  2. Elevate the screen ( don't detach)
  3. Remove the shield that connects the battery to the main board
  4. Disconnect the battery
  5. Hold down the power button at the top of the phone to remove and remaining power. (Device holds a little power without battery)
  6. Reconnect the battery
  7. Place shield back
  8. Reconnect screen to the phone
  9. Power on the phone
3 Comments:
I did this several times, even putting the old screen back on.
I even tried unplugging the battery connector and reconnecting everything again about 3 times
by
Updated my answer with something to try.
by
How would I determine if there is a particular connection at fault?
EDIT: yeah I tried that several times but made no difference
by
Add a comment
Add your answer
Dee Yonnie will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 89
