Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
Question Closed
My iPhone is turning off itself
Hi
My iphone is turning off a lot of times even the baterry is full. When I turns it on it ask me to take the password after restart :( It is like when I make hard reset. Sometimes I must connect to wifi because my signal is searching and the time is not set. Where can be mistake ? My baterry was before changing a housing in very good condition and I didn't have problem with it.
Add a comment
1 Answer
There a many different things that could be causing this problem, including things like liquid damage. However, as you have an iPhone 5, the most likely scenario is that your battery is failing. Failing batteries will appear to be normal when charged (they will look like full batteries), but will quickly drain and power off. You can take your device to an Apple store, and they can test the battery for you. iOS batteries typically last around 2-3 years.
1 Comment:
Hi thank you very much and I try change baterry because when is iphone charging then Iphone haven't any problem :) I think it is problem with baterry but I don 't know why because before change my housing, baterry lives more like 1 day by normal using ...
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 57
