Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
Charging Problem iPhone 6
I have an iPhone 6 that has a charging problem: if I replace the battery with a charged one, it works until it becomes discharged, then the battery can not charge again.
Add a comment
Chosen Solution
It's U2 Tristar charging ic at fault as it refuses to let a flat battery charge.
Score 3
2 Comments:
Thanks, how can i fix it? anywhere i can send to fix it?
by
Yes. You will need to look for someone that does board level micro soldering for iPhones.
by
Add a comment
Is there any resolution to this isssue? i have the same issue!
Add a comment
Replace the charging flex cable.
Score -1
1 Comment:
If it charges while not dead, how is it this?
by
Add a comment
Add your answer
hossam will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 226
