Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1233 Questions View all
Question Closed
iPhone 5c water damage error 21
I tried using rubbing alcohol (1st time) and that didn't have any luck, tried a known good battery and charging port (genuine parts) from another phone and still getting error 21.
My itunes is fine, tried dfu and recovery mode.
Ideas?
I realize it could be dead.
1 Comment:
An interesting note, I think the iOS did update as I was restoring, the itunes logo now looks different so I think it did update, but just can't finish.
by
Add a comment
Don't use rubbing alcohol! use isopropyl alcohol 99.9% to clean your iPhone board can you submit a picture of the water damage?
2 Comments:
The Red indicator is water damage so remove the black adhesive to expose the water damage [image|685796] then see if you see any corrosion on the board and clean it with ISO 99% and give a restore a try again.
by
yes works perfect but i do it differently more advance. Give it a shot just clean that area
by
Add a comment
Pics here
Doesn't look like anything is wrong, haven't used the isopropyl yet. Not experienced in repairing water damage, are they repairable most of the time after the isopropyl?
Add a comment
The Red indicator is water damage so remove the black adhesive to expose the water damage then see if you see any corrosion on the board and clean it with ISO 99% and give a restore a try again.
Add a comment
It looks ok but I will dump it in isopropyl anyways. Does that work pretty well for you when it comes to water damage?
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 180
