IT will not turn on
The camera will not turn on when I push the on buttom, I have a new battery
I would try charging the battery in the external charger and then installing it to confirm that it is operational. Here's a PDF on both internal and external charging: https://ftp.rush.edu/users/molebio/JohnT...
Replaced batery. Not good. A replacement batery will damage the device even if its an exact match. Put in the original batery and charge it and see if this helps. Even if the batery does not fully charge it should be enuf to get a responce on your device, if not do a warenty repair(you will have to pay shipping) i hope this Helps.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 610
