Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
Why wont my screen show any display?
When I connect my phone to the computer it is recognized and makes the charging noise.When I hold down the home button the voice control comes on.The only problem is that when I try to turn on the phone the screen lights up but its a black screen with a blue tint .So I know the phone works but nothing displays just a black/blue screen and I know its on because theres a crack near the top because when i press the power button a white light shows up then turns off when i click the power button again.Please someone help
Add a comment
Chosen Solution
Yeah, you've broken your display assembly. It's fixable, if you want to do it yourself, just takes some time
iPhone 4 CDMA
iPhone 4 (CDMA/Verizon) Screen
That's for phones on sprint or Verizon. There's a different part for GSM phones, such as at&t or T-Mobile
iPhone 4 (CDMA/Verizon) Screen Image
Product
$34.99
Add a comment
Most Helpful Answer
It sounds like the LCD on the device has gone out
Score 1
5 Comments:
Am i able to repair this on my own because once when the lcd was disconnected after dropping my phone i opened the back and presssed back into place
by
I would disconnect the ribbon cable and insert it back in if it's still doing the same thing then unfortunately the LCD gave out and needs to be replaced with a new digitizer.
by
and DO NOT press on the back of the shield once you open the battery cover, by doing that you could damage the ribbon cable or circuit chips that are underneath. Find a small screwdriver and take the shield off and disconnect the ribbon cable and pop it back in, it may not be seated correctly.
by
Also when assembling back together put the screws exactly back were they came from, there are different sizes of screws and you don't want to put a screw at a place where it doesn't belong which could cause damage.
by
You can check the inside to make sure its just not a loose cable. The repair is something you can do yourself! iFixit has the part and guide!
by
Add a comment
How long has that been doing this?
Score 1
1 Comment:
It has only been doing this for a day
by
Add a comment
Add your answer
Lisa will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 76
