Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
Question Closed
My iPhone 5 won't startup even with the hard start
i have an iPhone 5 that will not start the normal way or even when pressing the power button and home button at the same time.
What would be the next step and/or what should I replace first. I'm thinking the battery??
Add a comment
1 Answer
Generally, the process a technician follows is as follows
1. Test several chargers and connectivity to the computer
2. Make sure charging jack is clean of all dust and lint
3. Attempt to exit DFU Mode to be safe, hold both Power and Home Button for 10 seconds then release only the Home button
4. Change the lightning connector
5. Change the battery using a charged battery
6. Change the screen
This is the process I follow, usually I am able to find what is wrong within these guidelines
Regards
Best of Luck
iPhone 5 Battery Image
Guide
How to replace your iPhone 5 battery
Difficulty:
Moderate
15 minutes - 1 hour
iPhone 5 Lightning Connector and Headphone Jack Image
Guide
iPhone 5 Lightning Connector and Headphone Jack Replacement
Difficulty:
Moderate
1 - 2 hours
iPhone 5 LCD and Digitizer Image
Guide
iPhone 5 LCD and Digitizer Replacement
Difficulty:
Moderate
40 minutes - 1 hour
1 Comment:
Thanks Stephen
I'm now on step 4 of your solutions and just ordered the lightning connector. I'll let you know if that works.
Regards
Kevin
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 459
