Question Closed
Laptop will not run unless plugged. In
I have a 17inch 2.4 processor MacBook Pro. I have two. New batteries and a new power supply. My problem is , the unit will not work on battery power. As long as the u it is plugged in, it works well. I can also remove the battery and it stays on the plug stays yellow. The battery icon states. " normal ".
How can I fix this ?
Thank you.
Add a comment
1 Answer
Most Helpful Answer
Download and run Coconut Battery to get a better idea of what is happening with your battery. I actually suspect a defective Battery connector board. coconut battery
MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Battery Connector Replacement
Score 1
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 70
