The fifth Google Nexus phone. Officially announced on October 31, 2013, it sports a 4.95" 1080p display, a 2.26 GHz Snapdragon processor, and LTE support. Powered by Android 4.4.2, KITKAT. Manufactured by LG.
222 Questions View all
Can I replace the memory card?
I broke my 32gb Nexus 5 but im possitive the memory is still in tact. Im buying another nexus 5 and want to know if it is possible to open it up and put in my old memory into it?
Score 1
Add a comment
Chosen Solution
yaheyaarakil you are correct. The memory cannot be removed from the Nexus 5 it is not made to support a standard micro sd card, instead the memory is stored via the internal RAM.
However to answer your motherboard inquiry, it CAN be replaced. You can access easily by carefully prying off the back cover held by plastic clips and removing the battery and mid frame along with the interfering components.
iFixit already logged the teardown for your use : Nexus 5 Teardown
And the part can be purchased online for about 80 bucks, plus shipping of course. Id recommend searching eBay first before venturing toward other avenues.
Score 3
Add a comment
Most Helpful Answer
I am fairly sure that you can't replace the memory card (correct me if I'm wrong) The memory card is usually soldered (embedded) into the Main Board. There is no way of replacing the memory card without some soldering skills. Visit a certified technician for more accurate answers.
Score 3
2 Comments:
Can i replace the main board?
by
yes main boards are replaceable.
by
Add a comment
If the broken Nexus 5 was signed into your google account, you can sign the new or repaired nexus 5 in to the same google account and restore your files.
Score 1
Add a comment
Can one unsolder the main board's SanDisk and access the data on it somehow if the mobile itself is broken?
4 Comments:
No. cannot be done. it is not feasible to unsolider or read from it.
I read about a pc diag tool to connect using usb and perhaps. But I have not been able to spot one yet.
by
Thanks for your response. Too bad, though, I had hoped that one could save some data...
Is there any way to reset the OS in such a way that the memory card keeps its contents?
by
@maxmus yes it can be done. There is a way to recover data from a dead phone like the Nexus 5. Unless you explicitly chose to encrypt it, or the data storage itself is damaged, data is recoverable. It is an intricate process but it is possible as we do it all the time.
by
what is the cost to retrieve data and photos from a dead phone nexus 5
by
Add a comment
Try http://www.wugfresh.com/.
It seems to allow for data backup depending upon the mobile state.
Also can perform Android OS reset or Upgrade / Downgrade etc
only drawback is - available on windows platform only
Add a comment
Add your answer
aguas blancas will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 14
All Time: 15,257
