The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
Region code incorrect message
I changed the driver in my PlayStation 3 now every time I put a movie in I get this message that says region code is incorrect what do I do
1 Comment:
i think it has to do with the Blis vs Bles thing if you used a driver containing a file with one of these you might have to replace it with one of the other kink.
by
Add a comment
1 Answer
It can be a different default region code of the driver which is not compatible with the movies. You should be able to change the region code of the drive for up to 5 times. So change the region of the driver to your place. If you can’t, you can also change the region of the DVDs. Here is the complete guide, check more details
Add a comment
Add your answer
randymuck0209 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 193
