A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
ps4 update bootloop problem.
I bought the Playstation off cl knowing it had a problem. Keeps failing updates. Ive replaced the hdd with ssd, and installed software with several usb drives. i also tried the software its on 2.04 and every thing between current 3.00. Before I have it repaired was hoping there is a fix. I was thinking maybe pulling the cmos battery. the error code is su-30631-3. model cuh-1001a.
Score 2
Add a comment
You have to upload the full system software not just the update
https://www.playstation.com/en-us/suppor... (scroll to the very bottom of the page)
apologies if you've already done this - but i made that mistake once
1 Comment:
I used the full 800mb software file of several versions.
by
Add a comment
I have the same Problems. Anyone a solution?
Add a comment
I have similar problem since my son tried to install the update a few weeks ago. we've tried installing the full version oo and although it appered top work, a couple of days later the PS4 just keeps rebooting and saying you need to install the system software.
Will try contacting Sony support, but if anyone has any answers as to why an otherwise perfectly working machine should just fail like this following update, I'd be grateful - so will my son!
TIA
Add a comment
Same problem and no solution.
Meme probleme et pas de solution de sony
Add a comment
Has anyone found a solution? Same problem here:(
1 Comment:
Have you solved the problem? Thanks
by
Add a comment
In reading online this particular error is caused by the NOR Flash being corrupted. The onle fix listed i have read is to unsolder the flash and decode the dumpfiles.
Add a comment
Add your answer
Kyle Simmons will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 17
All Time: 3,683
