Password not working after battery change
I replace the battery with a new ifixit battery but when starting the phone the passcode no longer works. I switched to the original battery and it works fine. I plan to change the settings so there is no password and try again but it seems like the device knows it is not a apple battery. Any work around or solutions. I will try to reseat the new battery one more time.
4 Comments
That's rather odd, never heard of this issue before. Remove the password lock with the old battery and then see if it works with the new battery
by miniarma
Never heard of this either. Please post your results
by iMedic
So I reinstalled the new battery and then received an error that the temperature is too high and the iPod need to cool down. Clearly there is an issue with the ifixit battery that I received.
by whitingt
Everybody makes mistakes. Maybe they gave you a bunk battery. Did this fix your problem? If not, did you try putting in the old battery? Pretty curious now
by iMedic
