The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3722 Questions View all
Rear camera and flash don't work
Greetings! First post here.
Recently, while in the dark, I noticed that my flashlight (camera flash) on my iPhone 5S was no longer working when activated from the control center. I then began to debug it by rebooting, resetting and then finally by upgrading from iOS8 to iOS9. None of these fixed my problems but during the investigation, I noticed that the rear camera was no longer working as well. After some internet searching I do not really have a clear idea of whats wrong, as such, is why I am here.
This is something that I would like to try and fix myself if possible but would like some ideas of what else could be wrong here and if there are any additional debug steps. After hopefully identifying the problem, I will likely need to purchase the part(s) and doing the repair... so any thoughts or advice here would be welcome as well.
Thanks in Advance.
Score 16
Comments:
I have also problem with my camera the flash is not working although u can used the flash but the result is bkurry but if u dont used the flash the capture picture was very good wht is the problem of this please help me
by
What should i do please help me and how much do i spend when it comes of the labor and all the accessories need please statemated
by
Flash is disabled iPhone needs cool down like that it was displayed
by
My iPhone camera flash not working & the rear camera not capturing; what is the solution or the cause of the malfunction?
by
My iPhone 5 camera not capturing but the video calls are working. Can you give tips to correct the anomaly?
by
Show 1 more comment
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
Most Helpful Answer
Quit out of any app that can access the iPhone camera – things like Camera, Instagram, Facebook, Snapchat, Afterlight, etc
Flip the iPhone over and apply very slight pressure against the physical camera hardware using a finger, it may depress slightly indicating this loose camera issue
Now try to use the Camera app as usual (from lock screen access, or third party app is fine), it should work fine now and take pictures as usual
So, a malfunctioning camera, no camera apps are working, and loose physical camera hardware on the iPhone? That clearly indicates a hardware issue, and whether or not it impacts many iPhone 5 users is not entirely clear.
Score 3
Comments:
Was very helpful!! Worked like magic. Instantly! Tnx a lot
by
woh great ..working excellent
by
The first time this happened I tried this and it worked fine. However my camera went back to being unfocused and the flash didn't work again the next day and I tried this and it hasn't worked?
by
Add a comment
If you have already tried to update the software and this did not work, you will most likely need to replace the camera unit, follow this guide for the Rear Camera Unit
Not particularly a hard repair to do, just be careful when pulling it apart
Best of luck
Regards
Score 2
Comments:
I had a similar problem with my i5S. The flashlight stopped working. The camera was fine. But, I still don't know why my flashlight stopped working
by
My understanding is that the camera and the flash LED are not in the same part/cable on the 5s as they were with the iPhone 5... If this is the case, it's not clear to me how fixing the camera will fix the flash.
by
The iPhone 5S camera can some times cause the Flash to not work, after a replacement camera the flash should work with it
by
This is awesome information. I will be ordering a camera asap and will report back.
by
I had to replace the main ribbon cable (difficult project) in the top of the phone that connects motherboard to pwr button, volume buttons, flash led, silence ringer switch.
by
Add a comment
I have the exact same problem recently. It started on snapchat so I deleted then redone loaded it but it still didn't work. Then I tried my camera and it worked facing my way but shots in front of me seemed to stop and the screen was black. Just now I discovered the flash doesn't work either and I don't know what to do.
Score 2
Comments:
i have the same issue.
by
Add a comment
My iphone is not work
Score 1
Add a comment
i had mine replaced and it worked for three days.. now its black again and i have no clue what to do. Did check cables and reconnect it.. still nothing.. and i also did a software reset.. not working :-( Anyone has a clue??? The shop told me that the motherboard was damaged and it couldn't be fixed... but then it worked for three days after that.. now its not working again...
Comments:
I think I had some water trouble but the only effect is the rear camera worked intermittently and the flash stopped altogether. However, I replaced the camera and the entire ribbon assembly that has the flash, and there was no improvement. Is there a certain chip on the logic board that is focused on the camera and flash control?
by
Add a comment
Mi I phone 5s back camera and flash not working in yesterday
Add a comment
My I phone back camera and flash not working
Comments:
Mine not working after update, worked before that. Wish I could help!
by
My iPhone 5s rear camera and the flashlight stopped working it's saying iPhone needs to cool down to enable flashlight
by
Add a comment
My iphone 5s cameras and flasher is not working. I have replaced the camera, software update(10.2.1), hard reset nothing worked for me. but the camera and flasher is working in another iphone 5s. i dont know what to do. And what part should i need to replace??
Please help!!!!
Thanks in advance
Add a comment
I have the same problem. The rear camera and the flashlight of my iphone5s is not working. When I open it its just black and has yellow triangle on far left corner saying "flash is disabled, the iPhone needs to cool down before you can use the flash" I tried series of suggested solution but still doesn't work. It's been almost a month now. What should I do?? Please. Help!!!!
Add a comment
Back Camera don't work flash light not working need cool down device iPhone 5s
Comments:
Need help someone please
by
Add a comment
Back camera cannot use to show to camera the I phone need to cool down before you can use the flash what problem suggestion me
Add a comment
This solution worked for me, press the camera with your fingers hard enough that you will not break the screen, close the camera app, restart or reset all settings. I open an iPhone once and camera is plugged with a notch so it could perfectly unplug or near to it.
Add a comment
Add your answer
Garrett Cooper will be eternally grateful.
Past 24 Hours: 56
Past 7 Days: 435
Past 30 Days: 2,094
All Time: 116,178
