My washer stops at the rinse cycle
Washer fills, agitates no problem. then the washer will not spin rinse
or anything else the washer is done. this is the same on all 3 different cycles.
There is no hum like it wants to go or any sound at all.
Timer? Motor?
Update (10/13/2015)
model 110.20922990. I don't believe it is a clogged drain. Because after you get the
timer past the wash cycle on any of the different wash cycles, there is nothing.
Not a buzz not a hum nothing. You can move the dial any place after the end of
the wash cycle and try to start the washer with no luck. You can go to the spin
cycle and try to start the machine no go. You can go back to the wash cycle nand
start it up no problem.
5 Comments
My whilpool washer won't cut off the water it does good on the other cycle
by Barbie Roberts
Do you think it could be the washer lid. Switch
by Barbie Roberts
Sorry Barbie, I really dont think the lid switch is your problem.
by Scott Gaskill
My Kenmore washer series 100 he will watch but when I get on the rinse cycle it won't it'll stop my light we'll start blinking will not do anything else help me please
by Elida Greene
I have the same issue as Elida Greene, on my Kenmore Gas Laundry Center (Model 2671532).
by Tom Barros-Wing
