Repair and disassembly guides and support for dish washing appliances.
705 Questions View all
Question Closed
Tappen DishWasher Model 611134 Soap dispenser door will not lock.
This is the first time this has happend and it worked (2) days ago.
I loaded the dish washer soap pod into the soap dispenser, went to close the dispenser door but it will not lock shut. The owners manual trouble shooting section solution say's ,
"Timer dial must be at "OFF" position in order to latch properly. If you use the unheated dry selection, the timer dial does not advance to "OFF" by itself."
We always have the "Heated Dry" switch on and I have tried turning the dial once around to make sure it is in the "OFF" position but it still will not lock shut.
Add a comment
1 Answer
Chosen Solution
If the dispenser latch is defective, the dispenser won’t open or close properly. Inspect the dispenser door latch for damage. If the latch is damaged, replace it.
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 61
