The April 2014 update of Apple's 13" MacBook Air features refreshed dual-core i5 and i7 processors, plus slightly increased battery performance.
313 Questions View all
Question Closed
Keyboard doesn't function correctly.
I have some problems with my keyboard. The volume goes up every time I press the spacebar or some thing pops up unexpectedly on the screen when I type. Does the keyboard have any problem? Or is it a software issue? Can anyone show me how to fix it? And what's the cost gonna be?
4 Comments
Need a bit more here. Did you get your system wet some how? Spill a drink into the keyboard or set the system down on a wet surface?
by
Are you up to fixing this your self? This is not an easy repair as you will likely need to replace the upper case which is were the keyboard is mounted.
by
Where should I get it fixed? I'm located in Dallas, Texas.
by
I didn't get any liquid dropped in it.
by
Add a comment
1 Answer
Most Helpful Answer
To help isolate the problem, hardware or software, start up in Safe Mode by holding down the Shift key on start up and let us know if the problem persists.
Score 1
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 88
