Model A1288 / 8, 16, or 32 GB capacity
451 Questions View all
Question Closed
Broken Home button Spring?
I have broken off the gold looking spring on the logic board, i bourght a solderer to put it back on and now I have lost the bit? where can I get this it is the gold spring part right next to the lcd connector? thanks
1 Comment
Help... The same thing happened to me!!
by
Add a comment
Chosen Solution
I believe the diagram for the home button is like this: http://imageshack.us/photo/my-images/215...
In that image when the digitizer is in place 1 and 2 are in contact with each other and 3 and 4 are in contact with each other. The button just completes the final connection.
A wire soldered between 3 and 4 would do the job if you lost your spring.
As for martinkreis:
The spring is soldered. (see my answer here: gold spring for Homebutton connection )
Score 1
1 Comment:
Hi,
do you know how this spring is fixed on the logic board?
Is it fixed with a screw or solded?
Which material should I use if I fix it self made?
by
Add a comment
Add a comment
Same here. I've read other forums where people have soldered a hair-thin wire to bridge the connection between the gold spring and the gold home button. All you need to do is bridge the connection. It is not the sensor that determines when the home button is being pressed, just the connector. That's what I understand.
1 Comment:
by
Add a comment
Hi,
Add a comment
my clip has broken off the number 4 in your diagram , can i get a new clip ?
Add a comment
where can i get a #2 Spring??
Add a comment
Could i just use foil?
2 Comments:
for replace clip
by
It probably will work but not for long. You need something with a bit of "spring" to it so it keeps constant contact with home button.
by
Add a comment
for replace clip
Add a comment
do you know whats it called and where i can buy it
Add a comment
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 3
All Time: 4,956
