Model A1288 / 8, 16, or 32 GB capacity
451 Questions View all
gold spring for Homebutton connection
Hi,
I lost the little gold spring (in the middle) for the Homebutton connection.
Now I want to fix a self made spring instead of.
Is this little spring fixed with a screw or solded?
Do you have experiences with replacing this spring?
Thank you very much,
martin
Score -1
1 Comment
Hi,
I fixed the little spring successful, but suddenly the iPod did turn on again. When I opened the iPod, the little spring was broken and lying on the logic board. Do you think the logic board is gone now, because the spring touched the little transistors, or will it work again?
It still doesn't turn on!
How can I find out if the logic board is broken?
Thank you very much.
martin
by
Add a comment
Chosen Solution
The spring is soldered. I replaced one and had to use a needle nose plier to hold it while I soldered it. Put a little solder on spring and a little on board and applying it will be a lot easier.
1 Comment:
Thank you very much, I am gonna try it.
by
Add a comment
if you no good at soldering..you can buy some
solder glue that will just stick to the connection
but its slightly expensive but will last you years.
Add a comment
Add your answer
martinkreis will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,334
