How can I fix the charging port?
I need help because every time I plug the charger it does not take charge what can I do to fix this problem please help.
Check and see if the charging port looks damaged. If it does then it will probably require a new one soldering on. Unfortunately it is probably quite difficult for the average person without the correct equipment. You should be able to find someone on here can help though.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 159
