Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
597 Questions View all
Question Closed
Wifi issues - broken antenna?
Recently my Wifi connection has suffered greatly on my MacBook Pro mid2012 non-retina. I now need a much stronger Wifi signal to have a working connection. I did not change my position at my desk (home and office) nor the router hardware.
The plastic clutch cover had a small crack for 2 years already (on the antenna connector side). But now I suspect that the antenna may have broke. It seems that when I press on the crack reception gets better for a while. Is there a way to sort that out? I was thinking one could, for instance, measure the electrical resistance of the antenna connectors. Any ideas?
If it should really be the antenna where could I get a replacement?
Thanks!
UPDATE:
It is the antenna - or rather the antenna cable.
Any ideas where I could get these cables?
Add a comment
1 Answer
Chosen Solution
It appears the cable has been cut. Here is one source for the needed parts:
Score 3
Add a comment
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 1,418
