A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
1697 Questions View all
eject bouton doest work
hello everyone a have a big probleme with my ps4
i teardown my ps4 because a was doing some sticker bomb on the case and when i rebuild the console the eject bouton wont work at all but the power bouton work greats can someone tell my how to fix it please :(
Update (10/01/2015)
i have this forme at the end http://prntscr.com/8mr06l
Add a comment
1 Answer
Chosen Solution
There is a small metal tab on the bottom plastic that has to touch a copper pad on the motherboard. If that metal tab was bent or is misaligned it will cause the problem you are having. I'm guessing it's one of those two things. I would remove the bottom plastic and inspect that metal tab, then make sure it lines up as you put the case back on.
I hope this helps!
Score 2
3 Comments:
It's definitely pushed back too far. It needs to be bent forward toward the front of the case. After you get it bent forward then just put the bottom plastic on in a way that you can watch to see how it lines up with the copper pad and adjust as needed.
by
i check and its touch the cooper square but nothing work
by
OK...if it's touching the square contact point then the most likely problem is that either the ribbon cable going to the optical drive board is not aligned in the connector or there's also a 4 wire connector that might not be connected. These are the next things to check.
by
Add a comment
Add your answer
raphaeldesbiens will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 97
