Why isn't there any image on the screen?
When I try to connect the Amazon Fire TV device to my TV using a HDMI cable, all I can see is a black image on the TV. What can I do to fix this problem?
If you are getting trouble with Fire TV then you can restart device. You can use remote to restart.
Clear app data
See step 2 in my things already tried
yes its working.
its working
We had black screen with audio, though. Fixed it by unplugging everything……
Worked like a charm! Thank You!
Worked beautifully!! Thank you!!
Thanks , that fixed this issue!
This worked! Thank you!!
This worked perfectly!!! Thanks so much ❤️❤️💯💯
Fire TV Black screen is the one most common issues while operating with a device. Most of the reason/cause behind this problem like slow internet, loose cable connection, Hardware Impairment with HDMI port and more. In my case, the issue with the internet connection. So, to resolve internet issue, I followed some steps that I found on here and you can also try these steps:
Step 1: Try using different HDMI cable.
Step 2: Connect the HDMI cable to a different HDMI input port.
Step 3: Restart your router.
I googled this problem. It said to restart the Fire Stick by holding down the select button and the start button and IT WORKED!
I tried to restart this way and it worked the first time!!! Thank you!!!
Worked for me too first try.
Where is the “start” button?
What!!!! This totally fixed it! I’m in heaven. Hold down the select and play/pause button!
I had the same problem. Unplugged everything, plugged it back in, and no change. I then reset the firestick via the remote by holding down the SELECT button and the PLAY/PAUSE button, that solved it for me!
Try these steps and troubleshoot your Amazon Fire Stick
1.) The first thing you should check is your tv is on the right input for the HDMI input from the Amazon Fire TV. Then make sure both connections are secure the correct tv input port and the Amazon Fire TV output port.
2.) If nothing seems loose and you still have no image on your screen, check for any cuts, scrapes, or damage to the HDMI cable. If another cable is available, switch it out to rule out the cable is not working.
3.) If you still have no signal try another tv, then try turning off the Amazon Fire TV and wait 5 to 10 seconds. If none of the above the steps resolve the issue, you may have physical damage to the port. You should then refer to the troubleshooting page:
I'm not able to see anything on my screen to see if its on the right input, any suggestions?
Your memory is full or it reached the maximum storage of 5gb, try to replace the mother board since Amazon can't provide you on how to restore or reset to factory settings.
I skimmed through all the things you did to try and get it to work. I don't think that I saw this solution: just replace the USB cable. I was having the same issue as you and I did all the things that you did to try to get it to work. Then I just switch the cable and problem solved.
Yep, I get blank screen but can still hear the clicking when i press the remote. Only thing that fixes it for me is yanking the power cable out and back in again.
I need to do this 2 or 3 times a week now. Decent service, terrible hardware!
What's the start button????
'''Amazon Fire Stick Black Screen''' is the one most popular issues while performing with a device. Most of the reason or cause behind this problem like slow internet, loose cable connection, Hardware Impairment with HDMI port and more. In this case, the issue with the internet connection.
I had this black screen, after getting a message about slow internet. After I fixed the internet problem with my modem and router, the screen was still black. Kind of by accident, I pressed the setting key, and then everything was OK again. Hope this helps someone, as you can try this before blindly changing cables, inputs, etc. Good luck.
Unplug the power to your actual screen and the FireTV stick. Wait 30 sec, then plug it in. Works like a charm for me.
Amazon Fire Stick Black Screen is one of the major problems that can happen at anytime. It was really a very annoying situation when you want to watch your favourite TV show or movie and your fire tv screen get black. If you face this type of problem, then do these basic troubleshooting steps that I found '''here''' to get your Amazon Fire TV Stick in working back again.
I hope this troubleshooting steps will help you to get your problem fixed.
Hey it seems your misguiding people with links.
I tried all these recommendations. Nothing worked. Toshiba will never get my money again. This tv is just over 3 years old
I had this problem too. As well picture and NO audio. Fixed it by plugging Fire Stick into a different USB port
Causes For The Amazon Fire Stick Black Screen Issue:
If you have tried all the aforementioned solutions to fix the issue of Amazon fire stick black screen after logo but still the issue prevails in your device, then you must contact us as soon as possible. Our technical team is at your service 24X7, you will get assured solution for whatever problem you are facing with your amazon fire stick device. You can come up to us regarding any Amazon fire stick related problem and get the guaranteed working solution for the same.
Past 24 Hours: 11
Past 7 Days: 50
Past 30 Days: 235
All Time: 193,463
9 Comments
I have a question. I have done troubleshooting for my fire TV and it just shows Amazon on TV screen but unable to use Alexa on remote or pull up any applications for the past few days. Does this mean I need another gaming remote. Light shows blue on box and remote and just frustrated...
Thank you,
Any help would be appreciated..
by susan cooley
I have the same problem, i.e. no image from the AFTV.
[B]Background[/B]
The box was working perfectly.
I powered it off for a couple of weeks and when I attempted to use it again, it seems to power up, but there is no picture/menu/logo displayed.
[B]Things I've tried so far:[/B]
1)Powered off and on again - no change. The light on front flashes normally and then stops flashing. No flickering/image on TV.
2)Pressed select "Select"+"Play" to reboot the box. I can see the LED go out and then come on again. No flickering/image on the TV.
3)Pressed "Up"+"Rewind" - I can see the LED on the AFTV change to orange and flashing for while, but again no image on the TV.
4)I can successfully ping the box from a PC.
5)I've disconnected all other HDMI cables from the TV and carried out all the tests above - no change.
6)I've disconnected the AFTV from the HDMI cable and replaced with a laptop - this works perfectly, I can use the TV from the laptop.
7)When the AFTV has gone to sleep/standby and the TV is switched off, pressing "SELECT" wakes up the AFTV and switches on the TV, but still nothing is displayed.
So it seems that the AFTV is functioning correctly and receiving commands from the remote, but it still refuses to display any image/picture/icon/menu, i.e. anything.
Any ideas? Something else I can try? Known problem? Can fixed by opening the box?
Thanks in advance
by Chris
Pertaining to fire stick. Amazon prime app not showing image but I can hear the audio. Working with Hulu Netflix etc. please help
by jcheek18636
Netflix and HBONow on my my firestick would not show video but both would play sound. Netflix had full menus and even played the subtitles when I turned them on. I had other video apps that were streaming with no issues. I read somewhere that this was possibly a bandwidth issue. I power cycled my modem/router and firestick. This is what solved the netflix sound with no video issue for me. Hope this helps - Good luck.. (Power Cycle = disconnect power and re-connect power)
by Ken Mayes
Thank you for the advise this definitely worked
by sales.fnomovement
Show 4 more comments
