Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
586 Questions View all
Question Closed
2012 MacBook Pro 15" motherboard and screen in early 2011 MBP 15"
Hey!
I was wondering if it is possible to put a 2012 MacBook Pro 15" Motherboard and the Retina screen in an early 2011 Macbook Pro 15"?
I feel skimped out not having USB 3.0 and a Retina screen that the 2012 model has.
Cheers!
Add a comment
1 Answer
Most Helpful Answer
The Retina screens will not work on earlier models.
Score 2
6 Comments:
How so? Why won't it work?
by
They use very different signaling methods LVDS Vs internal DP. Think of it this way the gas & diesel engines can't swap there fuels as each was designed differently.
by
Thank you Dan! I think I get where you are going at. So, if I understand correctly, the 'problem' lies with the power signal starting at the input stage?
by
No, more like how older AM radios can't hear the newer FM signals (and visa versa). We are talking about the method of signaling here in the radio example: AM - Amplitude Modulated <> FM Frequency Modulated. This has nothing to do with the power at the input stage.
by
Hey Dan,
Thanks for the comment. I don't know that much about the finer details of computer technology so bear with me. Going with your analogies, this is what I want to do; I want to use diesel fuel in my gasoline car so I'm prepared to do a full engine swap!
I want to listen to FM radio on my AM set, I like the design of the AM set so much that I want to swap out the AM guts for FM guts.
Forum threads about swapping out the 2011 MBP motherboard for a 2012 MBP motherboard are plentiful. The only thing is they al get shot down at the screen connecters not being compatible. So, I want to explore the possibility of swapping the screen aswel. Hoping that the connectors will line up.
by
Show 1 more comment
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 116
