The Logitech Harmony Ultimate, released in Summer 2013, is a wireless remote capable of connecting to up to 15 entertainment systems at once.
3 Questions View all
Why is my remote's battery life so short?
The charging station is working and the device is able to turn on. The issue is that the remote is unusable unless its placed in its charging station for long periods of time.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
If you are not completely sure it is the battery try reading through the troubleshooting page to narrow down the possibilities. If you are absolutely sure everything else works then a bad battery is probably the cause of the issue. Check whether your warranty is still valid because the battery might be covered by it. Although if the battery is not covered here you can find a relatively cheap replacement.
Add a comment
Add your answer
Peter Stevens will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 109
All Time: 2,443
