Cannot start after swapping out Seagate 1TB HDD with 2TB SSD Hybrid
My native 1TB HDD had developed quite a few bad blocks and the number seemed to be increasing, so I replaced it with a 2TB SSD Hybrid. Before doing the swap, I put the new drive in an external enclosure and used CarbonCopy Clone to copy the old HDD to the new SSD. That all went well and generated a bootable SSD so I proceeded with the exchange. Old and new drives are Seagate, so I assumed the temp sensor would be fine and didn't replace it. I used the excellent IFixit guide to do the swap and the drive went in exactly as shown in the guide. I had a little difficulty hooking the four cables that connect the LCD screen to the computer, especially the flimsy Vertical Sync cable with the four foil ribbons. I wound up using a small piece of double-sided tape to keep the ribbons separate and aligned and attached to the plastic strip on the cable. After finishing with the LCD and glass screen installation, I hooked up all the external connections and tried starting the computer. Nothing happened.
My question is this: If one or more of the LCD attaching cables is not hooked up correctly, which one or combination would prevent the computer from starting? Or does it sound like I may have missed something? Is there some way for me to troubleshoot to find the culprit or is it time to call in the pros? Thanks in advance for any help you can offer.
10 Comments
when you say "Nothing Happened" No lights, no power or anything?
by Goulithum
That is correct - nothing.
by boneman01
I would say something else happened doing the re-assembly procedure. I'm not trying to be an @%^, because I've done it before...It is plugged in right?
by check4twenty
Yeah, I did get that part right. I also tried it with and wihout any attachments I tried holding down the start buttonor 15 seconds, then pushed it again several times. Still no results. Don't fret about hurting my feelings - at this stage I'll take any help I can get.
by boneman01
Try disconnecting the drive. Also do you think you put the display cable in backwards? Look at the connectors to see they are damaged.
by Dan
Show 5 more comments
