Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Questions View all
Power button does not work.
The power button does not work after liquid spill for now i run it by disconnect the battery and reconnected again my question are :
-are there any solution for this without open my mac avery day to run it ?
-what if i change the keyboard ?
Add a comment
1 Answer
Chosen Solution
To properly repair this you will either need to replace the upper case assembly or if you can find the correct keyboard replace it. In either case you'll need to take the upper case off. Follow this IFIXIT guide: MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement. Apple only sells the complete assembly which is this part: MacBook Pro 13" Unibody (Early 2011/Late 2011/Mid 2012) Upper Case (Apple P/N:661-6075. If you look on line there are a few suppliers of the keyboard alone.
MacBook Pro 13" Unibody (Early 2011-Mid 2012) Upper Case Image
Product
$39.99
Score 2
Add a comment
Add your answer
ahmad will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 132
