How do I fix my water damaged phone?
Okay so I bought a water damaged phone on Craigslist. I opened up the phone and I saw no water damage whatsoever. I plan to change the battery. The water marker stickers were red on the logic board, but I saw no signs of corrosion. What do I do? I plan to use rubbing alcohol to clean it up. The lcd water sticker was white, and it seems to have no damage as well.
1 Comment
I don't how to fix your iPhone, maybe you can follow these steps:
1) Turn the iPhone/iPad/iPod off.
2) Dry it off with a towel. Note: Do not dry it off with a blow dryer as this could melt the circuit board and other parts.
3) Put iPhone/iPad/iPod in a bunch of silica packets, or in the bowl of uncooked rice and cover it up.
4) Leave the device in the rice for at least 24 hours and preferably 48 hours. Hopefully, after 24 - 48 hours iPhone/iPad/iPod will have dried out, the logic board wasn’t damaged, and hopefully you can turn it on and the device will work. If not, your next option is to see if it can be repaired without much cost.
If you want to recover data from water damaged iPhone, you can follow the guide to do that:
How to recover data from water damaged iPhone.
by myrakern
