Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
no sound only during calls
the iPhone 5 has taken some heavy damage but it's still working fine, but when i make a call there is no sound. i can't hear the other side and the other side can't hear me, not even a dialling tone. i checked the earpice and the microphone with the voice memos app and it works fine, there is also good reception and i can surf the web and use other apps like Skype and whatsapp.
i did a little digging on the internet and some say the problem is the baseband chip U501_RF, is that true and if so how can IFIXIT?
Score 2
Add a comment
Chosen Solution
Hi nicolasphilippides
I figured it out. you will need to reflow the baseband chip. take the logic board out and with a hot air rework station heat the baseband chip. i used 350 degrees celsius with air pressure on 5 with a hakko station and 4.4 mm nozzle, heat the chip in a circular fashion for 30 seconds.
if that doesn't do the trick or if the problem reoccurs you will need to replace 3 chips as they are all paired:
1. Hynix H2JTDG2MBR (nand flash)
2. Qualcomm MDM9615 (baseband chip)
3. U601_RF (baseband memory)
which is not that simple so basically not really worth it on an iPhone 5 IMO. thats all the information you need, good luck.
Score 1
1 Comment:
Thank you very much :)
I don't have a hot air rework station but I will try by putting the baseband under a lamp for some minutes as I did for the greyed wifi problem on a 4S.
Hope it will work :)
by
Add a comment
Most Helpful Answer
Can you use the microphone and record things or did not work the game .Does music player through the speakers without a helmet. If all this work it may just be the Mic antenna. Here is a solution for it. hope this helps
https://www.youtube.com/watch?v=0jhWxYTV...
Score 1
1 Comment:
thanks Jimfixer
speakers and mic are working fine. recording, apps, music through the mic and everything but no sound on calls.
unlike the video the iPhone 5 chips are covered with metal casing, pressing on it doesn't work. should i unsolder the metal casing and try to reflow the baseband chip?
by
Add a comment
I have exactly the same problem...
If someone can help us :)
Add a comment
Add your answer
Nadav will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 397
