The HP Pavilion dv9000 series was introduced in 2006.
51 Questions View all
No sound Pavilion DV9000 (OS Vista)
I have the problem that the sound of my Pavilion DV9000 (DV9337eu) is not working. I have installed all the driver new, but there is no chance to hear anything. If i look in the settings of the sound i can see that it should works. If i connect an external speaker, i can also listen nothing. If i use the top components buttons for adjust the speaker level i hear by each using the beep. This means, the speakers are working propper. Is there an problem with the sound board? Can i change this, or is it onboard on the mainboard?
Can somebody answer me how i can solve this problem?
Score -1
Add a comment
1 Answer
Chosen Solution
Here is a link that worked for others. Give it a try--it might cure your problem. Good luck. Ralph
http://h30434.www3.hp.com/t5/Notebook-PC...
Score 2
2 Comments:
+ i had thise problem with my hp g6060eg - kicked vista out the day w7 rtm was released. (and btw - a pretty fast check for those problems are linux live cd's/pendrives, they work pretty good with standard hardware)
by
+ That same HP was my last PC. Crashed on me before 90 days.
by
Add a comment
Add your answer
Wolla will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 9,900
