mower drives for 5 min then stslls and stops
ride on mower will drive for about 10mins then chucks and comes to a stop .leave it for a while and it will do the same again
Check the gas cap vent. If the gas tank does not get air a vacuum with form and starve the engine out. After a while enough air will seep in to allow the gas to flow again.
I'd be more inclined to think that the intake manifold or carburetor bolts are loose, making it run lean, and over heat, since it has to sit for awhile before it will start again. Then rinses off and repeats. Could also be a gas line filter clogged and because of the tank vent it depressurizes the line, pulling the debris back.
If it were the gas cap vent, it most likely wouldn't initially start. If it did it wouldn't start again until you loosen the cap. Those are things that either work, or don't. That has been my experience anyways.
Nice to see you are still here Mayer. I am not kicking your answer. It is viable, just not something I have experienced as a solution for this type of problem. Have a great day! :)
Cellers, I have been here. You have not. Always nice to have someone question my august answers. Few have the chutzpah to do so anymore. But I do believe it is the correct diagnosis. Nice to see you too.
Mayer I made a comment. Do you remember what I do when I question a persons answers?
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 49
